The Rock-Clod Gallery: A place to post u'r clod in action!
My first crawler..
CFNN
Moab XL w/ Axial 40 beadlocks narrowed to 2.0”
Integy alum. tubes
RC4WD Knuckles
55T lathes w/8t pinions
Mamba Max
Hitec 5955 F/R
MPI regulator
7 Elite 4500 NiMH
Pimp`n Pony
17" Pimp Cane 1/8 scale X-Critter body
RC4WD internal gear reduction units Integy 55t motors
Tower Pro 945 (front) Hitec 5625 (rear)
Traxxas EVX esc Traxxas TQ3 w/ 4ws set up
narrowed clod wheels Gaint Trac tires
custom servo & battery mounts custom battery packs
Heres Mine. Its not really in action, but its here. (btw, if you get RC Driver, look on the last page of the show offs section, and you will see this picture."thumbsup" )
Chassis- NN
WB-16.5
Motors- Integy 55T
ESC- Tekin Rebel 2
Servos- Hitec HS645MG
Radio System- TQ3 with rear steer mod
(the crawler is the one in the middle :lol: :flipoff: )
Heres my scale clod
Axle snapper 55 turns
moped esc
tq3/ with 3 way switch added
home built chassy, with tube fenders
new bright hard body
lots of hand made goodies
working on new axle tubes as we speak
Four wheel steering
Modified Traxxas three channel transmitter for 4 wheel independent steering
Traxxas 3 channel receiver
Mamba Max Esc
Locked Clodbuster axles
Hi Tech HS645MG Hi torque front servo
Traxxas 2055 Hi torque rear servo
35t Integy motors
Adjustable motor mounts
Traxxas T maxx shocks
Moab’s on 40 series Welds
Proline racing chassis
Rubicon body
Alloy tubes and knuckles
Clod Crawler
Here are a few pics of my Clod axle rig
Still needs some finishing touches... Ran it around up at the cabin over the weekend, until the servo bolts escaped.... Probably should have used lock nuts "thumbsup"
Yes it is a Pimp Cane chassis
Lathe motors
EVX esc
Rear steer
2.2 tires/wheels
Wires need a clean up, and maybe a rear cover to hide the electronics.
Yard sale hard hard body... The chassis seems to flex nicely under the body. I will need to test it further and probably cut the front
Just a basic basher build, nothing over the top
all-most stock clod
I've had this one awhile, but finally have a good pic or 2 of it, just wanted one that was almost stock to play around with :)
Tekin rebel 2
45T motors
1 645 servo in the middle
homemade 4 links
jb weld locked diffs
1st clod build
just got a box of misc pces, screw, etc. 2 weekends ago and have managed to get it together
nothing too special, just clod axles, gecko 60/40 chassis, tq3 mod, hi tec front servo, 2055 trx rear servo ( for now ).
Running the stock tires and rims, ground out a bit of rubber on 2 so far just to try it out. Picking up narrow beads and moab xl's to mount on it.
my Defclod
Tiny Tuff Stuff LC chassis (aussie company) modified to run droop
V10 50 turn cans 9t front 8t rear pinions
Hot racing high clearance tubes and knuckles modded for TTR cvds
Novak Rooster Crawler
Moab XL's on 1.75" narrow Cheyennes
Custom BTA front and bashplate :lol:
Narrowed Kreepy Inserts (red fronts, pink rears)
My 2007 Chevy. K2-3L chassis, 15.5" wheel base, inetrc links, rc4wd rod ends, 10 pounds, Mamba max, custom 45t, ball diff's, narrowed clod rims. Needs tuning. Rips it up pretty good!
truck on the left is a gecko 60/40 chassis integy 45 lathe motors axial beadlocks with custom rings proline moab xl's tekin rebel2 spectrum receiver hitec 5745 servostruck on right is made from a tlt-1 new era chassis turned super style. 18 inch wheel base axle snapper motors, soon to be replaced with integy 45 turns stock t-maxx rims for now imex swamp dawgs for now novak super duty spectrum receiver. still in process of building for my girlfriend
