The Crawl Space
Time for another build from The Crawl Space "thumbsup"
I gotta say this one took way longer than I expected, the project was shelved at least 6 times to take care of service work on customers rigs but that what we're here for, customer service "thumbsup"
I've been wanting to build a 1.9 rig for a while and Tiff was cruzin' the local craigslist and found this rig for sale and I was struck with some inspiration.
I personally like to use hardbodies for scale builds so I picked up this wrangler body and poached a bed from a honcho for a quick mock up.
The bed wouldn't mount up to the body without some heavy modification so I put that to the side, but I'll use it as a model for the tube bed later.
I scored a used SCX10 frame and axles from a buddy and had most of the parts to start.
As some of you know us guys from Hawaii like to run our tires wide and this build will be getting the same treatment. I had a couple stock SCX10 beadlocks laying around and made up some double wide wheels for mock up.
Now on to the body work. I wanted a Jeep cab kind of like an old scrambler so I got out the dremel and razor knife.
I cut just behind the front widow and the door line.
Cut to the rear window "body post".
Got some old styrene sheet cut to mate the 2 body pieces back together.
I picked up some hardcore 2-part plastic epoxy from Ace hardware that was easy to work with and bonded well to the plastics.
I cut up some Dingo fender wells for a more wide look and just cool factor :mrgreen:
I patched the body with some Bondo and did quick coat of primer to get an idea of what I had.
That all for now. This is going to be a pic heavy thread and hopefully this build justifies it, thanks for looking more to come soon
