jeff22
I made a new bed and came up with a new mounting system. The velcro worked but wasn't great.
I thought the original bed was a little small so I made a slightly larger one.
To mount it I got some big washers and some rare earth magnets which are each supposed to be 5lb hold. I glued 2 washers to the bed mounting spot on the truck and then 2 more to the bed itself. The magnets sit in between the washers when the bed is mounted. This way the bed mounts securely but is also easily removable. It is easier to make adjustments than the velcro so getting the bed lined up is easier also.
I can also make different style beds if I want to and easily swap between them, I just need to glue two washers to the bottom of each bed.
Here is how the washer and magnet setup looks.
Here is the new larger bed mounted using the magnets and washers show above.
