rear end:
housing: Dlux (uses 5x13 inner pinion bearing) optional: Vp aluminum ar60 or currie
bearing caps: Vanquish products
lockouts: Vanquish products
axle shafts: Axial
lockers: Locked up fi spool, vanquish, super shafty, hot racing
gears: Axial hd, choose your flavor
truss: Vanquish products
link mounts: Vanquish products
bearings: Use a quality bearing such as fasteddy or avid
editors note:
i recently blew out the rear inner pinion bearing in my currie using a pro4 hd 3000kv. After doing some research and speaking with rowdy i ended up going with what he and his club have been using. It's an avid thrust bearing, size 5x11x4.5mm. If your using an aluminum axle there is no bearing mod like the dlux housing so it's something to keep an eye on if your using a stock type inner pinion bearing. Locked up rc also makes a bushing called the mini loco that is also supposed to be a fix for this problem, but i can not speak to how well it works.
