Soze's GMADE GS02 BOM Build
soze
Orange County, CA
So I'm joining the party of BOM build threads. Since the other threads show more of the custom mods, etc. I'll post more detailed step by steps for the stock build for those of you that want to see that, until I fully finish and then venture off into upgrading parts and modifying.
Here's what we're building.
Follow this build on YouTube - https://www.youtube.com/playlist?list=PLnWfHyV3LtMDy_StBW8EJELNBdAKseKe1
Most links are to items on eBay. As an eBay Partner, I may be compensated if you make a purchase.
Kit:
GMADE GS02 BOM (available on eBay)
Parts:
Yeah Racing Aluminum 540 Motor Spacer Heatsink (available on eBay)
Boom Racing 25T Alloy Servo Horn
Team Associated #5422 30wt Oil (available on eBay)
X-Rings from Traxxas 2362 Rebuild Kit (ebay)
GS02 Hardened universal shaft set (J30035) (ebay)
GA44 Heavy duty diff locker (GM30112) (ebay)
BOM exterior detail parts tree (Black) [GM60120] (ebay)
BOM mirror L/R [GM30128] (ebay)
BOM cage hinge (Titanium gray) [GM30137] (ebay)
Crawler Innovations 1.9 XL Deuces Wild Single Stage foams (available on eBay)
Pro-Line 1.9 Super Swamper TSL XL G8 Tires (available on eBay)
Injora 1.9 Beadlock Wheels (available on eBay)
Axial SCX10 Wheel Wells (AX31150) (ebay)
GS02 aluminum shock brace GM30130 (ebay) (currently unused)
GS02 stainless steel front under guard GM30150 (ebay)
GS02 cantilever sway bar GM30143 (ebay)
GMADE Aluminum 12mm Wheel Hub (4) (8mm Thick) GM30131 (ebay)
Gmade - Rear Link Kit, 324mm Wheelbase GM30133, for GS02 BOM (ebay) (currently unused)
Gmade - Rear Link Kit, 336mm Wheelbase GM30134, for GS02 BOM (ebay) (currently unused)
Gmade Cantilever Arm Set, for GS02 BOM (Titanium Gray) GMA30139 (ebay)
GMADE Komodo Roof Rack & Accessories (ebay) (currently unused)
SSD Pro SCX10 II Aluminum Knuckles SSD00144 (available on eBay)
SSD Brass Weights (Black version) SSD00140 (available on eBay)
Electronics:
Turnigy MG959 V2 Servo (available on eBay)
Yeah Racing Hackmoto 550 35T Brushed Motor (available on eBay)
FlySky R6B 2.4GHz 6-Channel Receiver (available on eBay)
FlySky GT-3C 2.4 GHz Radio (available on eBay)
Tools:
Versachem Brake Caliper Grease (eBay)
Noleen SF3 Grease (available on eBay)
Associated 1656 FT 1/4 in Driver Handle (eBay)
Tamiya Side Cutter (eBay)
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit (eBay)
MIP Metric Speed Tip Set MIP9512 (eBay)
Bob Smith Industries Blue Thread Locker (eBay)
ProTek RC Shock Pliers (available on eBay)
Molotow Liquid Chrome Marker Set - 1mm, 2mm and 4mm (eBay)
Tamiya PS-63 Bright Gunmetal (ebay)
Duratrax Gunmetal (ebay)
Steps 1-13: Axles
Let's begin
Parts needed for this step
Metal balls given to the first batch of BOMs
The well labeled hardware bags. Wish they would've went a step further and grouped the hardware by steps as well.
Ready to begin
Diff gears finished
Pinion Gear side of the axle
The other side of the axle
All greased up
C-Hubs going on
Front CVDs
Knuckles
Link mounts
Time for the rear axle
Front and rear axles all done
Welcome to the BOM club! You have much more patience for pics than I do. :)
How are your axles? Any crunch going on there? Just curious.
Yes on both axles. It's just one spot in the rotation though, not throughout. I wonder where in the assembly it's uneven causing that crunch.
Due to the crunch only happening in one section of a rotation, I'm inclined to think it's the assembling of the diff gear. Either I didn't put together that assembly evenly (which I did double-check), or the plastic housing on the diff assembly is molded unevenly.
I wonder if the upgraded diff locker would help with the crunch.
I know some of the parts are compatible with Axial SCX10 II parts and the gears look similar to the OG SCX10 so...do Axial gears drop into these axles? That might narrow down the crunching.
Don't have an OG SCX10, but I think those gears are larger? The pumpkin of the BOM is about the same size as the SCX10.2, so I don't think the OG SCX10 gears are the same size.
Steps 14-19 + 25: Transmission
We start with the B-bag.
Step 14 parts
Assembled gears
Parts for the next steps
Assembled and greased up
Spur gear goes on. They use stacked conical washers instead of a spring for the slipper. Directions say to fully tighten the lock nut, and then loosen by about a quarter turn. Here's how it looks.
Parts for the next step.. More e-clips yay...
Assembled gears...
Skipping to step 25 like new2rocks did.
Greased up. I wonder how the 2-speed option setup would look in this spot. That empty space has to be for something.
Transmission complete.
Make sure you snap that sucker down tight before the clamps go on...it's tricky. ;-)
Yep, sure did. This transmissions spins pretty smooth. Kind of surprised at how smooth actually. If I could only get the axles to be just as smooth.
Agreed!
I have a link the perfect size for mounting between the front shock towers for stability, but I hate to restrict my battery capacity that much....
Agreed!
I plan to address that as well once I get it built up in stock form. It'll give me time to think of solutions.
Steps 20-23: Links
This is going to be a pretty short step/post.
Bag of parts for these steps
Starting the front lower links
Front upper link
Rear lower links
Rear upper links
Steps 24 + 26-29: Chassis
Time to move onto the chassis. For this step, I also used the following non-kit items...
These are the parts needed for the battery tray
I'll be using the Turnigy MG959 V2 Servo and a Boom Racing 25T Servo Horn
Servo mounted onto the battery tray/servo mount assembly
These are the parts needed to start putting the frame rails together
It's starting to look like a chassis!
That under-frame receiver box that everybody has been putting weights in... I might do the same.
Time to get those links on
Links mounted
Parts for mounting the motor
I'll be using a Yeah Racing Hackmoto 550 35T Brushed Motor
So... I ran into a snag with this motor. The motor shaft is longer than normal, and I couldn't put the transmission cover on without hitting the motor shaft. So I had to get Yeah Racing Aluminum 540 Motor Spacer Heatsink
With the spacer installed, I was now able to have the motor shaft clear.
One thing I am concerned about is the pinion/spur mesh. It's tighter than I would like, and since the motor mount uses pre-set mounting holes, there's really no fine adjustment available. I will revisit this area later after I complete my build to see if there is a way I can make the pinion/spur mesh more to my liking.
Nice write up, especially for the parts you are using in your build. I am interested in how you like the Hackmoto 35T.
Keep the good work going "thumbsup"
Cruising right along there, soze!
Strangely, my pinion/spur mesh was almost exactly where I would've put it had there been more adjustment possible. It does seem sort of a strange arrangement as it doesn't take manufacturing tolerances of gears/spurs into account or allow for variance compensation. Not a big fan.
Great pics & write-up. "thumbsup"
I like that the battery tray is really low, but there seems to be a lot of extra stuff on the bottom of this truck to get snagged out in the woods. It'll be interesting to see how that plays out.
