"Clearance the trans case" = "modify the transmission case for more room"What exactly do you mean by "clearance the trans case"? Or more specifically, where at did you need the additional room?
Not too sure, but I might already say that it's the Mongoose system. 8)Looks good, whats your best hop up that you have done so far?
Thanks. I don't know about all 1.55" wheels/tires, but these have a 12mm hex on the back and fit the same as stock, maybe a touch wider stance but that's it. I've seen some 1.55" wheels with a pin mount on the back, but it looks like they'll fit too if you remove the hex from the axle.Great work.
Would 1.55 wheels and tires fit a stock mrc?
(direct fit, no mods to hub?)
