rockhugger
Any progress on the battery bank?
Lately I've been putting down packs on my original set of reduced silver Voodoo tires. I do not reverse Voodoo tires when I run them. Photos please.
Front
Rear
Thanks. As you can see, with unidirectional wear, the pins form flappy little ramps just before they shear completely off. I don't drive on ultra abrasive rock so these tires have continued to perform regardless of their state of wear. The set of silvers I drove at Nats looks brand new compared to these but these still work quite well. Their grip is remarkably smooth with very little hop (the pins fold over reducing hop). I'd actually comp these in this state. They lack that poppy snag of a Rover but their predictablility when traction is found is awesome. This silver compound rocks. I love the way it continues to soften up as is breaks in. I've not tried the blue compound yet but I'm a creature of habit and just haven't gone there. I'll drive the pins off of these to see where they hit the cliff. The inner hanger lugs are still like new...and work. Overall the silver compound still works long after I would have figured it would have dropped off completely. Are these as good as a similarly siped set of newer silvers with only 10 packs on them?... maybe not as far as forward bite goes (rock dependent however) but the overall predictability of handling may be better due to the softer, scuffed, pliable carcass and sidewalls.
Thanks Matt"thumbsup".
J
You need to mail me those old worn out heavy berg gears..:wink:
Awesome. I cant wait to hear the results.
Do you have part numbers by chance?
FYI, if you ever need to, when I turn down BB's I go further up the shock for even less pre load and more weight loss. If you take a look in the shock there is quite a bit of meat in there for a little way up.
Battery bank looks nice!!! Is it just for storage, or do you leave them in there while charging? Is it mainly a flame suppressor if one should spontaneously catch fire? I'm assuming you made a longer balance plug to reach. I use a parallel board, my only compliant is the batteries have to be close to it, and I can't keep them in my ammo box during charging... well, I guess I could, I just haven't made it happen yet.
all my packs blaze in domino format.
J
