SVEN
Awesome thread John! I love seeing this stuff.
Can't wait to see what's next!
What shop would be complete without some reference material? Not much to look at, but just enough to get the job done. "thumbsup"
You will notice it is heavy on the statistics and management. My two favorite reads: "Handbook of Small Electric Motors" and "How to Be a Gentleman"
Also got some really swank prototype armatures in the mail. Thanks to the Handbook of Small Electric Motors I used a little bit of math to specify the particulars of the new layout and hit the nail on the head first time "thumbsup".
Are you doing a "climb" or "conventional" cut?I'll try using ramp entry and see how that works. I'm coming in on round stock with the bit offset, so it is not a full plunge on the material but I could see how a ramped entry would really help the feed.
Chipped a 4 flute yesterday when the height got out of whack. I'm running a two flute on steel right now, yuck! Increased the spindle a bit and had to reduce feed rates 200% to keep chatter away. I have some nice carbide 3 and 4 flute radius mills on the way that should do a much better job.
I'm starting to hate the CAM program I'm using right now, DeskProto. Its actually really good for 4th axis stuff, but I can't control feed speeds on the first cuts without modifying the file direct and it spits out coordinates instead of G02 commands for circles. Can't modify the paths manually either. Just spent 40 minutes watching it cut some high precision parts (15 minutes cutting air) and then watched it bury the bit and attempt a full width cut at full speed :evil: Breaking the bit of course.
The file I just spit out for some 0.002" precision (file path) parts was almost a million lines long because of all the g01 stepping instead of just using circle or arc functions. Gimme some g02 codes dammit!
One little gem out of this is that I am pretty good at banging out Gcode manually now, although nowhere near pro. I'll keep my CAM software thank you :lmao: Gonna try hsmXpress now, and maybe see how MasterCAM is getting along since I used it last.
