Left my heat gun at the shop on Friday, and didn't feel like making a 60 mile round trip to go get it for rc body work. So.. I got some other things done today.
Relocated the rear sway bar once again. The arms are long enough that the tension bar still allows it to flex where needed, while keeping torque twist to a minimum. Fully usable now without the end rubbing on the shock springs.
Also, titanium gets REALLY hot when you're using a dremel cut off wheel to remove a corner that was catching..
Minor detail shots showing where I clearanced the radiator for a nice tight fit. Was determined to get it in there while keeping the chassis mounted servo, and using the lexan core support. Really close fit, but it works!
You might not be able to tell, but the core support and the radiator are actually mounted to the chassis. The front clip sort of floats over it in the front, and is going to be mounted to the frame at the cab.
Dash hackery! Need to get some styrene and extend that out a bit. Was worried about cutting it too close to the detail area and completely ruining it. Should be fairly straight forward to fit it properly now.
Best shot I could take at the moment to show how much room the cab actually has. I'm excited! I think I can get a full bench seat interior in there and still have room to mount my batteries saddle style on either side of the skid.
Had to change up my lightbar mount (again.) The windshield kept it from fitting close to the cage, but some chain links provided adjustable spacing. "thumbsup"
Also, I couldn't wait for my new Lipo's to come in (Why does Amazon have to be so slow?) so I plugged in a 7.2v nimh and did a test run today. Was really happy overall, but it's a very noticable difference running the nimh over the 3s lipo's I'm use to. Would barely skim up the loose hill dirt in second gear and cogged in reverse unless in 1st gear. Will have to play with the settings via castle link once the lipo's come in.
I also collected some scale body damage while I was out. Did you know the black RC4WD Mojave bodyset is painted, and is yellow underneath? :lmao: Good thing I bought a black paint pen.
