Scx10.2 rawbuilders kit wheel hopping
mikeyd5051
US
My kit is about a year old now its a scx 10.2 and it recently started wheel hopping /death wobble. Even going straight. Could it be bad bearings? Or need stiffer shocks or thicker shock oil? It has an injora cherokee hardbody and vanquish s8e shocks with 30wt oil in them on a hobbywing fusion 2300kv. Using SSD trail king axles with the axial bearings.
Sent from my SM-S908U using Tapatalk
What foams are you using? Might pull the front tires off and check them. if using standard foams that got wet, they may have broken down and be wadded up inside the tires.
They're the stock foams but that wasn't it. After work I tore it apart and it was my pinion mesh combined with too much steering angle on my axles causing the cvds to bind
