Turn down TLT shocks
How to: Turn down TLT shocks
syco133 said:I am working on a scale tlt build and was wanting to run the turned down tlt shocks but I wanted to do it myself and save cash for other things so here is what I did to turn them down.
First thing you need is a drill press a file and the tlt shocks
The second thing you need to do is chuck the small end into the drill press like this.
The next thing is to turn the drill press on and use the file to remove the aluminum from the shock body.
What I did was watch the shock body and keep removing material till the main body was level with the small end then when it was I removed the shock and chucked it back into the press so that I could turn down the small end just enough to remove the gold.
Here is a stock shock VS the turned down shock.I will use sand paper to do a smooth finish on them later on.
Here all all 4 shocks done and ready to be installed.
