RootBreaker
I joined the Band!
Ok she is done... tore the ford apart tonight and got this thing together..
have some tuning to do .. shocks are way too stiff and no real give... springs are too tight
Specs: (updates on 9/23/13 in red)
Body - Micro Raptor V8e
ESC - Redcat Sumo Micro
Steering Servos - Turnigy MG90S x2
Motor - Danally 90t Stroker Kit
Spur - 56t Aluminum
Pinion - forget when but has metal now
Trans - Losi Trekker
Trans Mount - Aluminum
Upper Links - (2015) Custom links from here http://www.rccrawler.com/forum/losi-micro-rock-crawler/519236-how-build-custom-links.html
Lower Links - (2015) Custom links from above
Shocks - Trekker Stock
Front Axle - Losi with Aluminum Knuckles and c-hubs
Rear Axle -(2015) Losi with Aluminum Knuckles and c-hubs
Tires - MiClaws
Rims - Danally offset beadlocks
Beadlock Rings - Fungi custom beadlock rings
Tie Rod - HR Blue Aluminum
Servo - Futaba S3156 Micro Digital Hi-Torque Metal Gear 33oz
battery - zippy 350mah 2s
not sure where to put the battery yet.. i can fit a 180mah 2s lipo up on the roof.. see that L plastic.. it fits up there..
Micro Raptor V8e-4 by TeleFragger / RootBreaker, on Flickr
I remember reading something bout the bic test... well shocks are stiff and it doesnt pass the test..
however I also remember in the 1/10 section that perfect flex is 1 tire height.. i can fit a spare bogger and flex on it.. so that is good
Micro Raptor V8e-3 by TeleFragger / RootBreaker, on Flickr
Micro Raptor V8e-2 by TeleFragger / RootBreaker, on Flickr
rear flexes a bit better....
Micro Raptor V8e-1 by TeleFragger / RootBreaker, on Flickr
now im going to try and put together the blue frame but that is next week..
going to fix the shocks and get them working a bit better and make this thing sit a bit lower... then play and have some fun...
Spur - 56t Aluminum
Tires - MiClaws
