It fits but a little notchy. Look in the losi mini crawler section there and a few fixes for the notchyness.
I remember doing the OD mod to my old MRC. It was a tad notchy but I didn't do anything and it worked fine. But that is a little different diff.
I have fit one in a stock barrage axle but never ran it or try to see if any fixes would work or shimmed it. That's the reason I never put it in the Bible.
Would love to have someone play around with it and give us feed back.
I'm a fan of overdrive. Always wanted to add it to my Barrage. But I just swapped RGT Bowler axles on to my Barrage, which have universals, so you get a lot better steering just by swapping to them.
But having overdrive to boot would be very cool. I may give the TRA7079 gears a try. I assume the internals on the Bowler axles are pretty much the same as the Barrage. Do I just need to change out the pinion, or both R&P?
