Anybody got a line on hardware?
I just looked up rc screwz and team KNK.
NUFFIN.
any ideas?
Metal scx10 rear shock hoop work front and rear on the chassis after you drill a new mount hole. If you wanted to a brace between the shock hoops stiffen things up quite well.
Go back to page #26 post #505 and on from there. those axles have already been swapped in to this chassis.
Just so I am sure you build is off the rgt which is the same as the barrage I am working with?Plastic ones work that's what I'm running.
If your using the stock location for the front the rear scx10 hoops are flat mounting against the top of the chassis just like the stock hoops.
The front sxc10 hoops are angled to follow the curve in the scx10 chassis. So if you move them to the curve in the barrage chassis they would work but then will the shock be long enough (if your still using stock shocks)
You can see where the back hole would be if moved back to the curve. The front shocks I'm using and longer then stock.
This is all great info and was instrumental in making my decision to go with the Barrage Gen2. I've made a number of small tweaks (mostly deletions) along with some important changes (servo), but one change seems to be elusive.....downsizing the pinion from the OE 22T to something smaller. I was able to get my hands on an Associated 21532 16T pinion but the can of the motor contacting the transmission prevents setting the mesh. I found a 18T 2.3mm pinion from Traxxas (7041) and will give that a try when it arrives.
Is the 380 from the first generation that much smaller of an OD than the 390?
Any chance there is a slightly larger spur gear out there that will fit? A 64T might be the limit but would also allow for a 15T or 16T pinion to fit.
Last question, and maybe backwards....Would it be worth downgrading the motor to a 380 to get lower gearing?
