84yoda
Post up aftermarket parts for the Losi Rock Rey!
Front Diff
-Hot Racing Twin Hammer aluminum diff cup Link
-Protek 2x8mm high strength 12.9 flat head screws Link
-Twin Hammer front locker (will need dremel work to fit with HR aluminum diff cup) Link
-Twin Hammer diff rebuild (just need the o-ring, stock o-ring will work BUT its a hair oversized) Link
-Xray 5x15x0.3 washers Link
OR
-Sworkz 5x14x0.5 steel washers Link
Center Diff
OR
Rear Diff
-VP Currie aluminum housing with dual 5x14x5 bearings Black Clear
-SSD aluminum 3rd member with dual 5x13x4 bearings Link
-Hot Racing Twin Hammers aluminum diff cup (will need dremel work to fit stock locker)
OR
Rear driveshaft
MIP:
-Super Shafty exclusive female shaft Link
-MIP male #10135 Link
-MIP #11111 (lip on both yokes will need to be ground down a little) Link
SSD:
-Wraith length (lip on both yokes will need to be ground down a little) Link
Trailing Arms
-JEC Racing: Stainless Steel or 7075 aluminum Facebook
Steering
-Losi aluminum servo mount, bellcrank Link
-Hot Racing aluminum steering rack/caster/knuckles/shafts/a-arms Link
Links
-JEC Racing SS steering/camber Facebook
OR
-VP Ti 55mm + revo and turn out to 72mm overall (camber) Link
-VP Ti 70mm + revo and turn out to 88mm overall (steering) Link
-VP SS rear upper links Link
Shocks
-Front: Proline rear slash 4x4 Link
-Rear: Proline yeti 5" XT Link
Bearings
-Fast Eddy Bearing kit Link
Other
-Proline 6" curved led light bar (stock mounts need to be cut off/ground down smooth, then fits perfect between roof mounts) Link
-TBone Racing accessories Link
I will try to continue updating this post but please feel free to add parts that pop up on the market. "thumbsup"
Front Diff
OR
Center Diff
OR
Rear Diff
OR
Rear driveshaft
MIP:
SSD:
Trailing Arms
Steering
Links
OR
Shocks
Bearings
Other
