roksloski
Does this run on Windows 7 64bit???????
As much as I'd like it to come to the 360 or PS3, I think it's better if it stayed on the PC, you can do so much more in depth stuff on the PC than you can on the consoles out now.I hope this gets made really indepth and put out on ps3 or xbox! That would be awesome for sure!
anyone ow whats going on? when i click on the icon to play the game, i select the setting i want and click "save and play" and the a window saying "run the RORconfig program first" as you can probably tell, im not very good with computers any help would be great. thanks "thumbsup"
the only thing i have thats close to what you said to open is "rorconfig" and i downloaded the beta version. .. . thanks for your helplaunch the RORconfig.exe
That will allow you to set the game up so it works with your computer better.
It should be in your start bar or on the desktop if not its in
C:/program files/ rigs of rods/
Launch that first. Then save and play.
And if you are launching using that then you what version did you download the stable or beta?
That will change the answer I give for fixes.
You can fix it, but its alot of work.
remove plugins.cfg from your main RoR folder(make sure you put it somewhere on your pc first, you have to put it back after using the configutator!)
then open the configurator, it works now, but it will display no render settings, so i am not sure if you can edit the vegetation level. You have to see it yourself.
Now put plugins.cfg back in the main RoR folder. With rorconfig still open.
i am having problems with this new virsion. every thing works untill i pick a terrain. a message pops up saying ground configuration to old copy skeleton/config/ground_models.cfg to my documents Rigs of rods/ config. i have no idea what this means
Double click on your "My computer" icon on your desktop. Double click on Hard drive C. Double click on your "Program files" folder. Double click on "Rigs of Rods" folder. Then double click on a folder named "Skeleton". After that, double click on "config" folder.
Now that you are here, make sure that the address bar on top of the window is like this: C:\Program Files\Rigs of Rods\skeleton\config
If you are in the correct folder, you should see a file named as "ground_models.cfg"
Use the right mouse button and click on the file, then select "copy"
Now close that window.
Open "My documents" folder found on your desktop, or your start menu.
Inside that folder you should see a file named as "Rigs of Rods". Double click it. And again, double click on the folder named "config"
Now that you are there, right click somewhere in the empty space, and select paste
Looks like a piss poor flat bed to me . I thought you of all people would know what a truggy looks like. :mrgreen:
I toy'd with the setting for a bit but not much luck. It runs faster but once i get into a car its back to square one.Try turning down some of the graphical settings in the configurator. I switched to the "sandstorm" sky, vegetation at 20%, and no water or dust effects.
NascarKeith, are you getting any sort of error messages when you try to launch it. You will need to run the configurator prior to playing the game. That was the first error I got, Error 9 or 6. The other error I got was Error 6 or 9, and was due to the fact that I was missing an DirectX 9 component. If you allow the program to direct you to the webpage it suggests, the wiki is really good about getting you rolling, either over rocks, or end over end.
Let me know what problems you have, both of you, and I will see what I can come up with.
