Resizing can be done many different ways, here is how I do it:
1. Open your .jpg picture, usually windows will default to Microsoft Photo Editor. My other computer uses Paint Shop Pro but it is the same procedure.
2. Click on "Image" on the header bar and then go to "resize" on the menu. See pic below.
3. In the resize window change the units to "pixels", check the box that is next to "smooth", and enter a value between 500 and 700 in the "width" box. The "height box will automatically change to maintain the aspect ratio. If the pic is taller than it is wide, then enter your value in the "height" box.
On some programs, you will need to make sure the box marked "maintain aspect ratio" is checked. Now click "OK".
4. There you go, click "file" on the header bar and "save as" on the menu if you want to save it under a different name. Doin this keeps the original pic unchanged for later use.
