On that note;
I'm surprised I don't see any more redcat guys "clocking" their axles these days. The performance benefits are huge, and that's not even to mention how it helps for tire steering clearance. It's basically just adjusting your upper links so that the whole axle rocks back towards the chassis a bit. Why you ask? For starters, this rolls the motor (the heaviest part, especially us 540 guys) closer to the ground, lowering the overall CG. Next, the arc that the tires turn in now passes below the shocks, instead of straight into them, thus alleviating rubbing. Also, it moves your steering links up and out of the way of snagging rocks. Now comes the fun bit of the REAL why; first there is traction. When turning, the corner lugs on the tire tread dig in a little more
Then the centre of the tire. Next, you know how when you drive straight up to your living room wall? And you let the front tires lift you upright? Well say you were trying to "turn" while going up the wall. So you give it full throw of the steering one way, and crawl forward. The tires bank one way, but the truck still climbs "straight" up the wall. No steering whatsoever. Because what little contact patch of the tire is hitting the flat surface, doesn't begin to see a turning angle until the whole truck is upright, balancing on its hind end!
So with the clocked axle, the head-on part of your tires actually seem to "lean" one way or The other during full throw during steering. So it those tight turn around spots, you can start your turning much faster and more effectively.
I got the idea years ago from checking out the bergs and bully's, and wondered why they have the adjustable C knuckles to allow for different angles.
See the very last picture on the bottom of the page I just linked to, here:
http://www.rccrawler.com/forum/redc...0-xt-unveiling-ongoing-build.html#post3044242
