Redcat Picture Archive - No talking
Few new pics.
New changes are :
Full droop suspension
Siped stock tires. About 100 cuts each
Switched to 2.4Gig using my DX6i
[*]Here's my RS10XT after about a month. Proline Chisel tires with memory foam, Zno
rear lockout, Zno spurgear pins, bent stock lowers, Traxxas upper link balls, $15 Ebay
5300mah battery, Body off a Maisto,2.75" ground clearance, T-Pro 946 should be here in a day or 2.
some current pics, better shows the chassis setup i have.
shows the way the "rust" effect comes through, this looks a bit off, next time i will use some different shades.
for the most part i think it looks decent
I want to eventually cut out the grill, the effect with teh fan should look nice for that scaler look.
the bumpers are off my old New Bright Rubicon
fatboyrs10 BUG
hey this my rs10 well what is left of it i only used the axles,shocks,upper links i had a 1:1 baja painted just like this i built the chassis and lower links out of delrin plan on taking it apart this winter and do a build thread on it:flipoff:
Greeting everyone, I decided to do a fast painting to my redcat and try some reflective tape and this is what came up.;-)
This is really the second paint applied.
Then I removed the covering tape for some areas
Applied the reflective tape.
And mounted the body back to the chassis.
And of course after 2 month of use, some climb, roll overs and crashes!
My RS10XT build
So here is my RS10XT that I have been doing some mods to.
List of changes:
FlySky GT3B Modded
DIY rear dig
Upgrade servos
Losi rock crawler tires
Lowered body 1"
Furture Upgrades:
New Chassis
New Shocks
Dual ESC's
rs10 xt not much upgrades pretty much stock.
hitec 645 mg servo
HB rovers white dot
home made rear end lockout
7.4 3000 mAh NiMH battery
buggy body
lowered to 3'' ground clearance
