~~~RCC Speed Shootout!~~~
Ok so for the crawler class it says it must be a crawler body. Does that mean a scaler or a puller body would be ok as long as its truck-ish or what exactly did you have in mind?
I am using a crew cab truck body.
Our main thing we didn't want was people to use high downforce/touring car bodies for the crawler class.
Truck, Jeep, FJ, ect you'll be good to go.
i think my main problem is that i have to much downforce on my rear wing and no front wing. also im running a very low weight set up. long story short, im using a 1/18 motor in a 1/10 kit w/ 1350mah lipos. im also using super sticky (their is no way the treatment im using is legal in competition) 2.5 inch foams, the added traction and an extremly heavy throttle finger really isnt helping either.
i have some ideas for keeping the wheels on the ground and this shootout has resparked intrest in my kit. (havent touched it since jan)
Sorry for the delay in replying. The rear wing down force doesn't kick in till the car gets to about 50 mph. If you are popping wheelies after that point yes, you will need a wheelie bar. If you are popping wheelies from start line to until the rear wing kicks in, that's due to a combination effect of motor torque and low weight/weight distribution (40F/60R is a good starting point for a 24" car) which absolutely requires a wheelie bar. I am not saying what I "think" to be true, this is what happens at a RC drag race with high traction.
You are spot on that you will have to be very careful with the throttle when you do speed runs. A wheelie bar just makes it more forgiving.
Just saw this last night on accident. Got my mind spinning last night and started searching for parts. Is it too late to start a thread and enter? I have a vision for a crawler class entry.
nope, however drivetrain efficiency plays a big part in top speed. a 2wd car, such as the drag race designed chassis use the most efficient drivetrain you can have in an rc. 4wd is great for handling and racing, however if you can get straight line traction with 2wd, why have 4wd???
You answered the question yourself, because a 4wd sedan would be much easier to drive to higher speeds, and in a shorter distance. 2wd on an unprepared surface is squirrely at best.
the weather is not gonna let this happen for us..i think rob got a test run in maybee..hopfully we can try this in the spring or even better the summer ..better for traction, get some higher speeds maybee..but ya pretty much been pissing rain for 2 weeks with only a few short breaks, not giving enough time to set anything up..bummer
Weather isn't going to let me get the video by tonight:-( Rained today and is going to tomorrow..... We need a extension!!!!!
