R1 Knuckle-mod
offroadace
Garden Grove
OK. So I've had an R1 for a while now and had 4WS, but recently removed it because I didn't really like it. This caused a problem and my turning radius was greatly reduced. I started looking at the aluminum knuckles and saw they were crashing into the portal housing. I probably could have investigated high knuckles, but didn't want to spend any money on it. Then I figured I'd just get the grinder out to see what I could do to help the situation. This is what happened! 8)
Not sure how much more angle I achieved (forgot to measure) but now the knuckles do not interfere with the housing at all. Now it limits on the servo throw.
Marked off some area that was interfering with the housing on both knuckles.
This is after I ground down the area.
Did the same thing to my r1 but even removed the bolt it was close to an shaved that to 3 bolts held it just fine, the high steer knuckles are the ticket! but ya still gotta grind some, not as much.
Thats been awhile ago i owned the r1, thinking i bought them from the crawler store, or rpp hobbys? traded the r1 off for a scx, broke alot of inner portal shafts!
