on alot of runs ill.take a rig with 10.2 axles and 1.9 tires and a 2.2 on portals the 10.2 will go everywere my other rig with portals on 2.2s will go
i dont think it makes enuff of a diffence from a drivers perspective to worry about
run them and have fun
It’s really comes down to the driver IMO. yea, portals have a little bit more clearance, but while my Dad was running his TRX4, I was following in the 10.2 going everywhere he was, we both had on 1.9s. If you are a good driver a pick your lines right, you can go anywhere-portals or not.
Fwiw, I did the incline test using a piece of plywood with the TRX4 and the 10.2. The 10.2 went almost all the way to the top while the TRX4 kept flipping about half way up. (Unfortunately don’t know the incline)Ran the same G8 BFG Krawlers, the same battery, and no body to keep it fair. The TRX4 is significantly heavier and spread out weight while the 10.2 has most the weight up front. Maybe it’s the weight isn’t up front like the 10.2, maybe it’s the ‘higher cog’ portals that kept flipping the TRX4.
_________________
SCX10 ii
TRX4
