Phildirt
The color is Rustoleum Neon Green over automotive primer. Spent a lot of time on prep so should hold up fairly well. The cage is also sanded/primed and sprayed Aluminum Metallic.
The kid wanted a less depressing color so this is what she got. May add some pearl ghost flames, can’t decide but this needs to cure for a while anyways.
Thinking about lowering this thing a bit. For those that have done it what shocks did you use? I have the rear body posts bottomed out and the fronts set just high enough to make the body level.
