papabash
I'm using the Losi Mini Late Model shocks (part no. LOSB1289) for this build, but I don't like the way the tops of them are just drilled holes in metal tabs, so I modified them a bit. The hard mounts really limit the amount of play the shock has during articulation. By cutting it off and replacing it with the Pro shock cap, it moves much more freely with less binding. It probably wouldn't be an issue if the shocks were left in their stock position, but when outboarded (either with the Losi outboard kit or with the BWD Bomb Proof mounts) the hard mount really tends to bind up pretty badly, at least for me. First I cut the tab off with a hacksaw, then used a flat file to smooth it up. The pictures show a before and after shock, and how the top looks after cutting and smoothing. Note: I also replaced the tiny shaft ends with the ends from my donor Pro Roller shocks.
After that, it was a simple matter of screwing the cap on from one of the Losi Pro Roller aluminum shocks. The diameter and thread pitch are the same on both shocks, making this an easy mod:
