Build is shaping up quickly.
I have dubbed it 'What-N-TarNation' though that has nothing to do with the Paint Theme I will be doing on the body.
Should have it set as a roller by this time tomorrow, if not artr. I have a SW4/5700 here I am probably going to toss into it for now.
have to get a servo. Have a decent Hitec here that should work out well. Its an older one, but its digital and pretty fast at 6.v and has plenty of torque for steering a drag rig.
Traxxas TRX4 chassis rails.
RCAWD (not rc4wd) SCX10 ii skid plat
Atomic Front Shock Tower
traxxas 2wd front bulk head
Slash F Arms
Atomic Castor Blocks
Traxxas steering blocks
2 No name f and r aluminum bumper mounts/chassis braces
SSD Wraith High Ratio Tranny
Vanquish Top Shaft
Vanquish Idler Gear Shaft
Robinson Racing Idler Gear
TA Slipper
Fast Eddy Ceramic Bearings in Tranny and Backyard RC Ceramic Bearings in SSD Axle
Traxxas bearings in front steering blocks
Traxxas front turnbuckles
SSD O.D. Gears and Metal Cover
SSD Titanium 4 links and various ends
SSD Long Drive Shaft
SSD 90mm shocks
Cantilever rear shock system
Traxxas Funnycar Front and R Wheels
STRC 12mm hexes for the rear and 12-14mm hex adapters for the funnycar rear wheels
Traxxas Front axles
SW4 and 5700
Hitec 7685? steering servo
stock Traxxas bellcrank
Traxxas and DRC Hinge pins for the front
Pro-Line '56 F100 Body to be done in a Theme
Slash F Arms
Vanquish Top Shaft
TA Slipper
SSD 90mm shocks
Traxxas Front axles
SW4 and 5700
