Official Chesapeake, VA beach, Suffolk Trail Run Thread
That's what I'm running the mamba max pro with a tekin 13.5. Do you guys have a suggestion on programing? Drag brake etc. I have it geared to 32p 12/56t robinson racing. . Still trying to set it for crawling and speed
Sent from my SCH-I545 using Tapatalk
Drag 40%-50%
Start-up power High
Cheat mode I think 22 deg at 7200 rpm? Chime in Bo, my memory fails.
I will be at hell climb sat "thumbsup" if you want to go to Richmond will go there if you change your mind again :lmao:
Drag 40%-50%
Start-up power High
Yea, I think I have my CHEAT starting at 20,000rpms, ramping up hard and fast. I remember yours being lower and more progressive though I'm not sure it was that low. We set yours up lower since you only run 2s primarily, as opposed to me running 3s usually. When I run 2s I hardly hit cheat mode (3100 RPM/V motor * 8.4V = 26000 RPMs with fully charge battery)
What does the advanced timing get you? I need to turn the drag down a bit
Sent from my Galaxy Note 3
Lots of wheelspeed. We can talk how it actually works this weekend if you want, but for now you can think of it as a turbo that comes alive at a set RPM and builds boost (timing) as the motor RPM increases. "thumbsup"
Drag preference is a personal thing, but I'd say all us should be in the 40-60 range.
Ass. Tons of ass "thumbsup"
Hot ass
:mrgreen:
That is essentially the same setup I run in the FJ40, sensored of course, and I love it. It works very well, a ROC412 or Pro4 is about the only way that setup can get better. What batteries are you running? See my post above about the cheat mode regarding 2s vs 3s CHEAT mode setup. My personal feeling is that this setup needs no less than 3s. I find that with the 2 pole motor my low speed torque suffers too much with the 2s battery, plus you have to gear it too tall for speed which leads to heat issues in situations that require torque. No issues on 3s though.
I run minimal mechanical timing on my motor (I think the lowest that motor can go is 2 degrees). This keeps the motor cooler, plus it doesn't get too crazy when you start adding timing with the CHEAT mode. Advanced timing = more heat.
Depending on rig weight, 40-60% drag brake. I run 60% on my 9lb rig. It depends on how you like your drag brake setup too though. And I think I run 30% brake? That may be incorrect its been a while since I messed with it.
I also tune my throttle curve down within the ESC a little bit so it is a smooth takeoff.
Thanks. . I'm running a 2s 4300 mah.. Thinking about getting a 3s but not sure which one to go with. This is ago New to me but the information you gave is very helpful
Ive run three or four different set ups in my crawlers. Ive run brushed, brushless with and without sensor. I love the Holmes brxl esc. I doubt ill ever run anything else in my trail rig. You can always get ya a sidewinder3 from castle. It will run brushed or brushless. Im sure there are other's that have that capability as well. Ill stick with the Torquemaster and a 27t or 35t brushed motor. It just works best for me.
Popcorn for President!!!
Lol there is no room for interrior. Ill have to get the dinky split skid and make it a rear motor you really have to see the cage to see what im workin with
Sent from my LG-LG870 using Tapatalk
And i need a smalllllllll battery.. the full 2s lipo is too big for it. I can only mount it to the under side of the roof. And its really too top heavy rolls over a lot.
