MIKO
Holy shit just making a joke, terrible counters guys, terrible. What is a MambaMaxPro?
That's what I'm running the mamba max pro with a tekin 13.5. Do you guys have a suggestion on programing? Drag brake etc. I have it geared to 32p 12/56t robinson racing. . Still trying to set it for crawling and speed
Sent from my SCH-I545 using Tapatalk
What does the advanced timing get you? I need to turn the drag down a bit
Sent from my Galaxy Note 3
I run 100% drag I think. Makes for interesting stops.
It's a castle esc Miko
Drag 40%-50%
Start-up power High
Cheat mode I think 22 deg at 7200 rpm? Chime in Bo, my memory fails.
Drag 40%-50%
Start-up power High
Ass. Tons of ass "thumbsup"
I will be at hell climb sat "thumbsup" if you want to go to Richmond will go there if you change your mind again :lmao:
That is essentially the same setup I run in the FJ40, sensored of course, and I love it. It works very well, a ROC412 or Pro4 is about the only way that setup can get better. What batteries are you running? See my post above about the cheat mode regarding 2s vs 3s CHEAT mode setup. My personal feeling is that this setup needs no less than 3s. I find that with the 2 pole motor my low speed torque suffers too much with the 2s battery, plus you have to gear it too tall for speed which leads to heat issues in situations that require torque. No issues on 3s though.
I run minimal mechanical timing on my motor (I think the lowest that motor can go is 2 degrees). This keeps the motor cooler, plus it doesn't get too crazy when you start adding timing with the CHEAT mode. Advanced timing = more heat.
Depending on rig weight, 40-60% drag brake. I run 60% on my 9lb rig. It depends on how you like your drag brake setup too though. And I think I run 30% brake? That may be incorrect its been a while since I messed with it.
I also tune my throttle curve down within the ESC a little bit so it is a smooth takeoff.
