This has been my most successful combo yet as well. Motor stayed cool, wheelspeed was improved, but I still wanted more.in my lnc im running stock gearing thru a 35t handwound motor and 20 tooth pinion with a 7.4v 2200mah 2cell lipo exelllent wheel speed and good torque no heat issues at all
hope this helps
paul
Which led to:
Tried a 3s. Things went ok when I tried a half charged battery(around 12V), glitchy but usable as the battery dropped volts.DO NOT use a 3s LiPo with the stock ESC. Bad things will happen and a fire may result. :shock:
Things went bad quickly when I tried a fully charged 3s. ESC won't even power on now at all. I wasn't using the Castle BEC, but damn, all I did was turn it on and pull the trigger. Seriously. Tried to power through a glitch and that was it. Done. No smoke, no fire, no started working again later. Just done.
So, I have a HH Torquemaster and 7T Cobalt Puller coming.:mrgreen:
There are threads here with people saying it's ok, run a CC BEC, etc. It may work out for some I guess, but my 3s experiment went poorly enough that I can't say I'd recommend that anyone try it. FYI- Losi is talking about a setup for the LCC, not the stock LNC stuff.i noticed on losi's site that jake wrights comp set up includes an 11.1v battery. would this be advisable for the stock motor , and electronics of the night crawler ?
