Mongopotamus
I am fixing to swap in a LCC tranny into my LNC... will the LNC shafts work with the LCC tranny?
Wat brushed motor/esc should i use in the lcc? and also wat gear should i use?
Will an Integy Matrix Pro Lathe 55t motor work with the stock LNC esc in a lcc?
Exactly. Motor turn's do not affect gear ratio's as the final ratio is determined by the gears of the motor pinion, transmission and worm gears.
Maybe if you looked at it in 1:1 scale that would help.
Take a Chevy Nova for example. Using the same transmission and same rear end gears the final drive ratio doesn't change when you swap the 305 motor out for a 454.....right? Sure you gain some tire shredding performance with the 454 but that is in the motor not the gearing.
Same applies here. A smaller turn motor will increase the wheel speed, but the gearing didn't change....the motor did.
The subject is about getting the same wheel speed out of the LNC as the LCC.
Both rigs are running the same motor / ESC / battery setup but the wheel speeds are different.
As I am sure you know, the worm gears are the same in both rigs so that rules out them affecting gear ratio's. The motor pinions could be the same tooth count so that rules out them affecting gear ratio's.....so what is left?
The transmission.....and there in-lies the difference. The gear ratio of the LCC crawler tranny is different than the LNC.
I don't believe there are tranny gears available for the LNC that are not stock tooth count. And I don't care about being the "LCC Master" as I already stated in the disclaimer portion of my first post...I am not an expert but rather somebody willing to help those new to the LCC and LNC.
Ok, hopefully when I get home from Chicago I can start putting mine together.
I have a Goat 3s, 18.5t and ordered a battery from MaxAmps last night:
# 2000mah Capacity
# 7.4 Volts
# 45mm X 69mm X 18mm
# 60C - 880 surge watts(120 amps)
# 120 grams
# 5C Fast Charge Capable
I have a 12t, 13t and a 14t pinion.
So which pinion would you run 13t ? Also am I going to sorry I didn't go with a 3s battery?
Ordering V3 CVDs tonight also, anything else I should look at, other than the usual loose screws and greasing?
OK here is one for you guys...
LCC, Mamba Max Pro (high start power, low timing, sensored mode), Novak 21.5T motor, using a 3S lipo...
All is hooked up, but it cogs worse than any set-up I've ever seen! I've had sensorless set-ups that were smoother than this. This all got started by the Goat 3S esc shutting down randomly (including flat ground). Originally thought it was the esc... now with Mamba Max Pro, I get some nasty cogging.
So.. time for a new motor or what? Cracked the motor apart, found 1 broken sensor wire which I fixed, no other real problems. After fixing the sensor wire, it is still a cogging mofo.
No signs of scorching or other issues, but I'm gathering the smoked motor smell isn't like that new car smell where you want to have it :lol: This was apparent when I split the motor to look at it tonight.
Sounds like you may have a broken wire in the sensor harness. Has the motor gotten extremely hot? The smoked motor smell isn't good.:shock:
Goat 3s 18.5 12t pinion"thumbsup"Thanks for the replies. Now i know i should go brushless on the lcc i am (planning) to get. thanks. But now which brushless system, or brushless motor/esc combination do u reccomend?
If you want my honest opinion....putting a 2s LiPo in a 3s setup is like putting a 4 cylinder in place of a V8. Yeah, it will work but you will never utilize it's full potential.
The battery you bought sounds like a good one, but you will get much more torque and wheel speed if you had gone with a 3s version.
I run the Goat 2s Crawler system in my LCC and it does pretty good and has plenty of power and decent wheel speed, but it is currently torn apart awaiting the Novak 3s with 18.5T Ballistic motor.
I would start with the 13t pinion and see how that works. If your motor runs cool all the time, you might try the 14t. I run a 14t in mine once in a while, but I have to keep on top of the maintenance otherwise I run into heat trouble. The 12t works good too, but at a sacrifice to some wheel speed.
V3's are definitely the way to go. My LCC is awaiting a set of those too.
Make sure you double check the spool shims and make sure there are only one per side, then pack as much grease into the housing (between the spool bearings) as you can.
Loctite the driveshaft set screws and you should be good to go.
