What CMS bracket do you guys think works best with these? The VP front bumper version or the HandBro/RC4WD one?
The SSD one will work best: CHASSIS MOUNTED SERVO KIT
I believe the bumper one is suppose to be used with the currie Panhard which includes the frame side Panhard mount.I'm inclined to say any of the brands that mount the servo parallel to the chassis rail over the VP bumper mount. I have the VP mount on my truck and it has taken alot of trial and error to get both full steering throw and minimum bump steer. Plus the VP bumper mount requires you to source a panhard mount for the chassis while it is included with the other kits.
I found when trying to fit vp hubs i had to remove the bearing then the c hub slid on easier. Then i pushed the bearing on. I suspect they would have come off easier if you had pulled the bearing out first.
There are slight tolerance differences between SSD parts and VP parts. This is normal for all brands. I recommend you use a rotary tool (dremel) to sand off some material (0.1mm) around the bearing housing on the ends of the D60 tubes. This should solve your tight VP parts problem.
Of course you could have just used SSD parts and not had this issue: PARTS FOR SCX10
We are working towards having complete SSD axles so these issues dont happen in future.
The hub going on half way then toght was like mine. Removing the bearing solved this. As for the brasstubes I suspect it might be the screw that secures the truss to the housing touching the brass tube. Remove that screw then install then put back the screw. As for the tight fit of the lockouts I think you might need a light sand or dremil as the bearing is not in the housing but the lockout isn't it?Thanks for the quick reply and the tip. I'll dremel the ends a bit when the new C-hubs arrive. Completely my fault, even though this is my first crawler I've been in RC long enough to know better than to force things together with a hammer.
Quick question though. Is there a possibility that the truss when tightened pulls up on the housing causing a slight bend. I ask because…
> I test fit everything without the truss and it all went together. Then with the truss on when I assembled ll the parts, that when things went on tight including the SSD brass tubes. The tubes just slid in easily without the truss, with the truss I had to tap about the last third of the tube in.
> the Vanquish c-hubs and lockouts went on about half way then the got tight to the point that I tapped them on.
This is why I ask if there could be a slight bend from the truss.
Unfortunately being new to crawlers I wasn't aware of SSD when I ordered all the upgrades. I didn't learn about SSD until I started reading this forum. By then I had already invested in VP upgrades. Seeing the quality of the SSD products however as I need to replace parts from wear ( as apposed to being stupid a hammering brand new parts) I'll replace them with SSD products.
Couldn't you run the locked up chubs with the ssd knuckles?
Sent from my Nexus 4 using Tapatalk
Ya know I don't don't have the truck in front of me, but working from memory I think the bearing goes into the housing and is held in place by the lockout. I'll have to look at when I get home.
The truss screw is what I thought was causing the problem with getting the tubes in. I backed them off and it didn't change anything, I completely removed them and nothing changed.
So I'm kind of at a loss as to the cause. I'd guess it is just a light brush with a dremel to fix it, but it's weirded that it all fit before I put the riffs and the trusses on. If I wasn't concerned about not being able to get them FG again what I consider is installing the tubes, chubs, duffs then the truss to see if it makes any difference.
I don't think I want to take another 100.00+ gamble. So I'll probably play it safe a light dremel the ends of the axels to get the lockouts and chubs on. It won't take but a very light touch of the dremel.
What I will do though is reassemble the broken parts in that order and see if it makes any difference.
