The VS4-10 Phoenix Portal RTR Falken Edition is the first VS4-10 Portal Equipped RTR from Vanquish Products.
So beatifull. RTR with Portals
Features the VFD Twin transmission,F10 Portal Axles, Phoenix body with bedsides, and a detailed interior. Included is a full function digital 4 Channel VT-1 Transmitter with multiple model memory and end point adjustment, making the VS4-10 Phoenix Portal RTR ready to be equipped for fully functioning Dig and Selectable OD. Or run it out of the box with 6% OD powered by a 35T VM-1 Motor and VE-1 3S capable ESC. The large diameter Stainless Steel links bring high end Vanquish Products kit quality to the RTR market. The drivetrain is equipped with machined ring and pinion gears, machined portal gears, chromoly universal axle shafts, and chromoly 6-bolt spools for the ultimate in durability. Full ball bearings, metal transmission gears and 32P spur / pinion provide smooth and reliable performance when tackling the toughest terrain.
The VS4-10 Phoenix Portal RTR Phoenix Edition is equipped with the VFD Twin, incorporating Selectable Overdrive Shifting and 3-position dig ready (servos not included*) into one compact package.
Phoenix Body with VRD1 Cage
Falken Tire Livery
Painted Cab, Bedsides, and Interior
VRD1 Rear Cage
3-Piece Body Design
Headlight and Tail Light buckets
Molded Grill
Hinged Design
Hidden body clips with quick release front pivot pin
Wheels and Tires
1.9 Falken Wildpeak M/T - RED Compound Tires
1.9 Incision KMC KM233 Hex Beadlock Wheels
VS4-10 PHOENIX PORTAL RTR FALKEN EDITION SPECIFICATIONS
1/10th Scale
Falken Wildpeak RED Compound 4.65”x 1.9” tires
5.25:1 Axle Gear Ratio
15T/52T Pinion/Spur
20T/28T Portal Gear
Overall Width: 250mm (9.84")
Overall height: 250mm (9.84")
Wheelbase: 313mm (12.3")
Overall Front Ratio (Standard 6.5% OD): 53.7:1
Overall Front Ratio (Optional High 46% OD): 35.8:1
Overall Rear Ratio: 57.3:1
RTR weight (without battery): 6.0lbs (2.7kg)
REQUIRES
2-3S LiPo Battery or 6 cell NiMh (XT60 Plug)
Compatible battery charger for selected battery (XT60 Plug)
X4 AA Batteries (For transmitter)
*ADDITIONAL ELECTRONICS FOR OPTIONAL VFD TWIN FUNCTIONALITY
X2 Standard size servos for Dig and Selectable Overdrive (Standard or Low Profile)
X2 24mm servo horns
$579.99
SKU:
VPS09013
https://www.vanquishproducts.com/vs4-10-phoenix-portal-rtr-falken-edition/
I really like this one
Falken Tire Livery
VRD1 Rear Cage
3-Piece Body Design
Molded Grill
Hinged Design
Wheels and Tires
1/10th Scale
15T/52T Pinion/Spur
20T/28T Portal Gear
REQUIRES
X2 24mm servo horns
$579.99
SKU:
VPS09013
