Need some dimensions of the lcc trans.
xiteamxi
scranton
Hello wondering is some one here would be able to take a few measurements to help me out with a project i'm considering using the lcc transmission with.
Measurements im looking for
1 Height from top of skid were the trans sits to the center of the output shafts
2 Diameter if the output shafts
3 General width,height,and length(end of output to end of output)
4 If you knew the gear ratio of the trans that would also be appreciated
5 Also stock lcc axle is 25:1 correct?
Any help is greatly appreciated,
Thanks"thumbsup"
Here ya go bud"thumbsup"
Bottom of tranny to center of outputs is.14mm
Output shaft diameter is 5mm
General length is 74mm width is 70mm height 48mm output to output is 60mm
I have heard the gear ratio is .83-1
And yep 25-1 axles
Hope this helps ya bud"thumbsup"
