Hey Ben,
Thanks for the kind words.
Your light setup should be nice too, I'm waiting to see when you get it done.
I thought about 9volt battery too, but I hate buying any non-rechargeable battery. It's easier, less junk and less weight to just wire into your receiver, lipo balance tap, battery main power wires, or if you want separate battery, buy small 800 - 1000mah lipo dedicated to lights. Yes, less daylight and we go back to standard time first Sunday in November, so that has lit a fire under me to finish lights.
I got the lights from Professorcake in a great deal for a second set of Ascender tires, LED strip and wiring and plugs. I forget where he bought them, but there's a couple links below. "thumbsup" Our LHS sells all the different colors by the foot at reasonable prices.
R/C Country Hobbies - 15 Photos - Hobby Shops - East Sacramento - Sacramento, CA - Reviews - Yelp
HobbyKing stocks all colors too, great price too. Here's the red:
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
60 LED's per meter!!
LED's are arranged in sets of 3, you can cut the strip and make new strips or extend strips to make any combination of 3 lights!
Features:
Comes with adhesive tape backing for easy mounting
Flexible enough to be bent at any angle
Easy to use. Just peel and stick!
Large voltage input range up to 12V DC! (Great for 2-3S Lipoly)
Specifications:
Standard length: 1 meter
Strip width: 8mm
LED quantity per strip(1 mtr): 60 LEDs
Working voltage: DC12V
Working current(1mtr): 400mA
Wire length(1mtr): 10cm
Weight including wire(1mtr): 11g
Certification: CE & Rohs
Vaterra LED Light Bar Insert Slickrock (PART NUMBER: VTR310000) is a great pre-wired setup for rocklights (white, not red color) and can be used in their plastic housing (or make your own from styrene) as a forward facing lightbar on the bumper or roof.
Vaterra Light Bar Housing Slickrock (PART NUMBER: VTR210014):
Waterproofing electronics I've use MCG Products conformal coating spray (it can be sprayed into a small cup or jar and brushed on too). It works very well and is what most OEM waterproofers use. Corrosion X is something your dip the parts into, it does not dry, and must be re-applied periodically. I have not used Corrosion X, but others said it works very well. Do not use Plasti-Dip for waterproofing directly on electronics, it's way too invasive, messy, holds in too much heat, and can crack parts off of the circuit board in extreme heat/cold temperature changes.
