Do the black wheels, they look good too!
I used RC4WD silver hex hub adapter:
RC4WD OEM Steel 1.9 Stock Beadlock Wheel Hexes (4)
I don't like the silver RC4WD wheel hexes because all the little machined points sticking up chewing at your finger tips while assembling wheels and tires. :evil: The faux brake rotor versions would be very nice as you can see the back side is nice and smooth because the screw heads are on the wheel side, not the hub side, but these add 2mm to width on both sides, iirc the Slash front 2wd hexes add 3mm per side? This type of hex hub makes wheel/tire assembly easier because there's no nut to hold on the other side while holding everything else in alignment. :lmao:"thumbsup" I prefer the look of the little nuts on outside, they look like lugnuts. I've drilled couple sets of HR (Hot Racing) 1.9 wheel hexes that come with 2mm hardware, to use 2.5mm hardware same as RC4WD and did not end up with the sharp edges all over that the silver RC4WD hexes have.
Starting at post #172 there are pics and how to drill out wheel hubs too.
http://www.rccrawler.com/forum/axial-scx-10/324677-natedogs-honcho-kit-build-9.html
I originally bought the silver RC4WD hexes just for the hardware when I drilled my HR 1.9 steel beadlocks.
These hexes needs to have the screw head area drilled from 0.173" factory to 0.177" to clear the slightly fatter screw heads of most 2.5mm screws...easy to do, but takes time and the hubs still have the sharp edges.
I now have all four mounted with RC4WD silver hubs drilled out, next time I'll buy their faux brake rotor hubs and go back to stock width wheel hexes instead of Traxxas wider hexes.
I'm using Slash 2wd front wheel hexes on my SCX10 Honcho, they snap onto the axle cross pins and stay put nicely while addling iirc 3mm width per side. RC4WD 1.9"/2.2" 6 Lug Steel Wheel Hex Hub with Brake Rotor is a great way to get hex hubs and not have fingertip eating sharp edges on the backside:
FYI, the 2.5x8mm and flatnuts used on these wheels are slightly smaller wrench size than previous RC4WD steelies, I was using my 5.5mm Associated nut driver and it was too loose. Didn't find my 5mm driver and ended up 3/16" (4.7625mm) is very snug fit on the flatnuts, so maybe they are 5mm?
I also had to use my Dremel with coarse grit sanding drum and enlarge the center or the VP rings to fit onto the RC4WD wheels. I
opened the inner diameter about 0.020" for them to fit together easily.
