mgputer
Looks good. I was going to do the same thing with my spare front shock towers but I couldn't find it. I need to clean house and get rid of a few things but as soon as you do you need it! Never know what you can use something for!Full compression.
Full droop travel.
Some brackets I started but didn't finish to connect cut up shock tower to frame. Unfortunately it didn't come out too well because I couldn't twist them tight enough to properly clear the frame rails and it was bowing out the shock tower. I had all kinds of scrap servo mounts, angle, box aluminum, plastic pieces trying to brainstorm what to use. Due to my lowered receiver box, I couldn't drill and bolt it to that because it would penetrate the box where the lid screws go. A piece of flexible plastic handle from an old large art portfolio from school serves well once again, just cut the width down to 1/4" and used a leather punch to make screw holes!
Yes, the rear most third hole is drilled an tapped into the frame rail. It all clears the bed/cage, but I want to cut the body mounts off the rear towers for cleaner look and get some flex room for the cage when it goes for a tumble so that it's not bashing the cage up against the rear towers.
Ride height without battery.
Ready to rock n roll!
Keep us informed how your 3 link works so I can copy your idea when you get it right! [emoji23]
Sent from my ZTE A2017U using Tapatalk
