I got a tiny bit of clearance from using a skinny nut (not a nylock) and grinding down the bolt to be just long enough, and I spaced out the shock a good deal so the clearance looks even better.
I also cut down the plastic ball ends so there was no flare left just the main ball. Since the sway bar doesn't have much if any twist i think its fine to lose the flare on the ball ends.
I used Axial thin locknut, shortest stack height steel balls with the plastic endlinks, clearance enough and no binding. Your setup gives even more clearance and as you said the side to side twist of the ball ends is not needed in this situation."thumbsup"
During my K10 re-work I decided to upgrade steering links on the Va'Blazer and found out that WB4 cannot be setup with the servo on top of the mounts, because the servo horn will hit the frame when steering left. Nothing can be done about it the way the frame rails start to bend down right there. I had already spent a couple hours cutting and making it all fit, just can't steer in this configuration so I put the servo back for now and will check it again later how to make it work with servo under the mount in factory spot or maybe use sideways servo mounts from shorter WB to make it work. Here's pics of what I tried, had to cut up my mount and use one shorter screw through shock tower to crossbrace/servo mount on left side. :ror:
Edit: Just measured and the stock floating battery tray will fit again, but might need to cut off the raised cross piece at front of tray to clear the steering servo. Might cut it off anyways, don't need it and it's weight up higher than the axle center line. I've already lowered the rear of the tray same amount as Ben did (see Itali83 thread here in Ascender section) starting here in his Blazer thread: http://www.rccrawler.com/forum/vaterra-ascender/548229-my-baby-blazer-10.html
The Blazer gets driven really hard and I broke another set of front body mount posts, so I used these. The VTR23006 are Vaterra road car Body Post Set (4 per pack. These posts fit all the Vaterra V-100 chassis road cars.
http://www.vaterrarc.com/Products/Default.aspx?ProdID=VTR230006
I cut the posts shorter so just long enough, then drilled the one hole that the mounting screwpin goes through to 0.078" and then wiggled the bit around slightly, nice light press fit, installed and should last longer with all the holes being smaller size, therefore more material to resist breakage. "thumbsup"
After messing about with the Blazer, back to work on the K10. All electronics are in the receiver fuel cell box!
Dremelled outside of front lower links to get that last couple millimeters of up travel where they were contacting the frame, still plenty of metal left for strength."thumbsup"
Edit: Later found I needed to Dremel out lower down the sides of the links and a little more fore and aft of what I did in this picture.
