I bought a steering conversion kit for my Ascender back when I first built it; the kit looked like yours, but it caused TONS of bump-steer. I ended up going back to the stock steering setup because the geometry was better. (how it was better I have no idea, it just was.) I put an O-ring on the pivot connecting the steering link and the drag link together, so it wouldn't flop around anymore.
Works fine the way I've got my servo crossways and on top of mounts.
Down-travel limiters allow you to run the truck lower (which requires the spring adjusters to be further up on the shock bodies) without letting the shocks extend so far that the springs come off the carriers when the shocks are fully-extended.
"thumbsup"
Thanks to Ernie (Codyboy) for pictures and link to Erik DLux' build here on RCC! I saw the start of his build and hadn't checked back on it lately, good stuff as usual! I've been thinking about eliminating the TT a lot lately and been tinkering, looking back to my OG SCX10 and the tranny flip that killed it for that truck, tranny driveshaft output offset, etc.
Big thanks to Ernie and Erik DLux for ideas and no fear in cutting stuff up and trying outside the box ideas!
Link to Erik Dlux's build:
http://www.rccrawler.com/forum/axial-ax-10-scorpion/597118-dlux-has-gone-off-deep-end.html
TT theory starts about post 62!
Ernie's thread:
http://www.rccrawler.com/forum/vaterra-ascender/597251-codyboys-79-ford-rent-own-ascender.html
Thanks to Ernie for generously building and sending me a set of axles with rear panhard setup!
In garage and driveway testing this seems to help reduce torque twist, I'll be doing more real world crawl testing. I've done several days of mocking up with different mounts, link lengths/placement, etc. This coupled with Rich's Shock Collar Mod, rear upper link mount changed, etc are all pieces that help improve the Ascender, I'll be running this at Proline By the Fire! BTW, yes I know theres' no screw in the axle link mount in the picture. :ror: 8) Everything clears even with my lowered fuel cell/rx box.
In garage and driveway testing it seems to help. With longer panhard link like Ernie sent, mine was binding a bit on left rear full compression (articulation ) about last 1/4" of shock travel. Compressing only left rear it binds slightly for last 1/4” of travel, seemed like something with link geometry was out of parameter just slightly. Turned out right shock was hitting frame rail on articulation, easy fix used a spare shock piston to space out both rear upper shock mounts and no more binding/rubbing. :ror:
This combined with Rich Trujillo's shock collar mod, Vaterra stiff rear upper and lower springs, and maybe rulrs definitely improves the TT. Put them all together and it's getting where we want to be! I've played with this setup on my bench and yard for couple days with all kinds of links mounts etc. I had to buy new shock towers, swap out frame rail that I drilled and filled too much, but it’s all buttoned up now! So far it seems nice, but will find out on the rocks and trails for sure what needs to be done next.
