I've replaced the stock HiTec phillips servo arm retentions screw with 2.6x8mm cap screw and tiny washer with loctite.
Note at full left lock steering (tires gently rubbing lower links) the tie-rod can get blocked by the drag link ball end on the servo horn. I have not found any way around this, therefore it's beneficial to run a skinny tie-rod so that it clears better and it can slightly and gently flex to get past this point when travelling up or down in the suspension travel. I've never noticed anytime when it got locked with suspension compressed that it didn't flex slightly and travel past each other. This servo horn I'm using raises the draglink up (closer to the servo) by about 3 - 4mm than the thick stock plastic horn, allowing a little more suspensioin up travel (good), but does allow for this linkage rubbing to get closer than stock.
I'm going to look at my collection of steel links (skinny but strong steel) to see if something will work...iirc Billinvic used one for his tie-rod. Thing is I like the stock steering linkage, it just works well and keeps everything away from the tires inner sidewall. Might be able to run stock linkage and just replace the aluminum rod with adjustable steel linkage rod with Vaterra plastic end links. I have a slightly longer Hudy servo arm (super sweet piece of machining) and it will raise the draglink even little closer to the servo than my current setup. I think the slightly longer arm and the more clearance will be good. this setup as pictured ran at Bald Rock comp no problems at all!
