Natedog
New used Treps on HR 1.9 8-hole beadlocks with CI DW foams! Tires were rubbing front bumper at full lock (even though CMS reduced steering throw slightly) and rub front fenders slightly. Probably just live with front fender slight rub since I like my body low, but had to trim my front bumper little more to keep taller Trepadors from rubbing at full lock. Rear tires don't rub anywhere.
New Pro-Line Scaler shocks too...bought them over a year ago, just hadn't installed them as I was trying hopelessly to make stock Axial shocks not leak. These Prolines are really sweet so far....length and spring rates seems great too.
Some more CI foams.
I drilled the HR hex hubs to use 2.5mm hardware because they are stronger, clamp tighter and imo look better than the 2mm hardware that they come with. The wheels didn't need drilled for the 2.5mm, just cleaned the powder coat out of the lugnut holes by hand with numbered drill bit and they were good to go.
Some more CI foams.
