My 2013 Losi Sporty
TAG axle kit on the front, Jens is one of the first to show it mounted up on a rig. have to say his steering system is a lot cleaner than mine though "thumbsup"
The TAG kit is just awesome,-I had to limit the steering to avoid the universals to lock up :shock:
Mounted some Blue Monkey knuckle-weights and did a test-run today.
Really great to have that much steering and the caster-angle did work well also "thumbsup"
And added one more screw to the c-hub,-just in case ;-)
The steering arms are from Crawling Calvin,-another great product "thumbsup"
The drag-link is still not the final version,-would like to have it in titanium.....
Yesterdays final test before leaving to Germany and Supercrawl "thumbsup"
Silver Voodoos front and blue rear,DLUX wheels.
So far I like the tires "thumbsup"
My foam setup is a bit homemade,it's Nova 5.5 closed cell narrow inner with soft outer front and medium outer rear. But since that was a little small, I wrapped some foam from a car airfilter on the outside :lmao:
Home from German Supercrawl,car did very well,-but I lost my head in the last course and maxed out,-placing an overall sixth in 2.2 sportsman.
Did not comp with the voodoo's,not enough practice with them,so I went with the old rovers.
Small update :) Before I installed the TAG-kit I had bent front lower links. But with the bta steering it was a bit tight so I had to use straight links,then I found an off-set rod end from Traxxas Rally/LCG Slash (#7438 ) With a thinner titanium steering link from Crawlerkeller,-it was just enough room for the bent links again :)
First win this season today in the 2013 Norwegian Crawler Series :)
Only three drivers today in the sportsman class,but still I'm happy with the first place finish.
Car is great,-very happy with the awesome steering "thumbsup"
Now it's only the driver who can mess things up :ror:
Voodoo-foam-testing today.
Nova closed cell 6" inner with soft outer front and Nova closed cell 5,5" inner with firm outer rear,-no tuning rings. Sidehills much better and nice grip "thumbsup"
This will most likely be my set-up for the Nordics next weekend in Sweden 8)
Hi Jens,
thankx a lot for the tip of the TRX7438 rod ends.
Will do the update as soon i get the parts.
Have a niche weekend!
Regards The Joker
Third place in the Nordics this weekend :)
Very happy with that,-since I had a little fall into the ocean,and the servo giving up at the end of the last course,-resulting in a lot of points there...... :cry:
The car and the Voodoo's were doing great,it's me that have to stay out of trouble.......:mrgreen:
Great news Jens.... To bad for your servo...
send from my HTC One-X
Thanks 8)
Looks like it's just the BEC that's broken :)
Salt-water is bad,-so I'm tearing the car apart to inspect the damage.
