I had been waiting for the kit for months, but when it was announced it was delayed again... I decided to pop on the RTR. After deciding to get out of the 2wd buggy scene and selling my RC10B5M and everything that went with it, I had quite the amount of funds to work with. Below is my purchase list. Some of this I already have from the buggy, electronics and such, and some has already arrived.
Looking forward to the build/rebuild of the RTR and will be documenting the process along the way.
Axial 1/10 Yeti Rock Racer 4WD RTR
Electronics
Drivetrain
Steering
Body/Frame
Wheels/Tires
Electronics
- Tekin 1/8 RX8 Gen2 Brushless Sensored/Sensorless ESC
- Tekin Pro4 Heavy-Duty Brushless 2S 3500kV Motor
- SPC LiPo Power, Lithium Polymer (LiPo) Battery Pack; 6900mAh, 70C, 2S, 7.4V Hard-Case
- Deans Ultra Plug Pair
- Castle Creations CC BEC 10A 6S Switching Regulator
- Hitec HS-7954SH High Voltage Ultra-Torque Dual BB Universal Servo - HRC37954S
- Futaba 4PLS radio
- Futaba R304SB T-FHSS 4-channel telemetry enabled receiver
Drivetrain
- Robinson Racing Gen3 Slipper Unit 64T Spur w/Ridged Hub
- Robinson Racing X-Hard One Piece 32P 15T Idler Gear Yet (2)
- Robinson Racing Pinion Gear Xtra Hard 5mm 8 Mod 13T
- Robinson Racing X-Hard One Pc 32P 27T Diff Output Gear Y
- Axial Racing AX31135 Axial Universal Axle Set 94mm Yeti (2)
- Vanquish AXIAL WRAITH REAR CURRIE AXLE (Black)
Steering
- Vanquish Products Yeti Steering Rack (Black)
- Vanquish Yeti Sheer Steering Rack
- STRC CNC Machined Precision Aluminum Front Caster Block for Axial Yeti and EXO Buggy (Black)
- Axial Racing Aluminum Servo Horn 25T (Hard Anodized)
- Vanquish 12mm Hex (Black)
- STRC CNC Machined Aluminum Rear 4-link Mount (1 pair) (Black)
- Hot Racing YET2101 Aluminum Steering Knuckles Yeti
Body/Frame
- Vanquish Products Yeti Trailing Arm (2) (Black)
- RPM Front A-Arms Yeti and EXO Buggy (2)
- Blue Monkey Titanium Front Turnbuckle Kit for Yeti
- Blue Monkey Titanium Rear Upper Links for Yeti
Wheels/Tires
- Vanquish Products 2.2 SLW Hex Hub Set (2) (225)
- Vanquish Products 2.2 SLW Hex Hub Set (2) (475)
- Pit Bull 2.2 Rock Beast 2 (2 Pair)
- Single Stage Closed Cell for 2.2 Tall Tires (2 Pair)
- 2.2 Wheel Clamp Ring (4)
- OMF 2.2 Original Beadlock Black (4)
- OMF 2.2 Outlaw II Rear Ring Black (4)
- OMF 2.2 Front Wheel Ring Silver (4)
- Scale Wheel Screw Kit (2 Sets - 4 Tires)
