willyg1981
I used durafix 3in 1 aswell which is really cool stuff and quite easy to use
I went Mamba X w/ the Holmes Hobbies Puller Pro 540XL 3500kv in my Baja Rey and it's a fantastic sensored combo.
Had the Mamba X w/ a Castle 1410 3800kv in my Yeti and it seemed slightly underpowered, so def get the bigger Castle motors like the 1515 you mentioned if you prefer to stick w/ Castle.
You might have to do some dremel work to the motor cover, depending on the pinion you choose, with the 1515.
Im going to be installing a MMX and Holmes PP 540XL 3500kv with 10T pinion, on 3s. Should be uncontrollable, lol.
Yeah your right there's only about 3 mm spare under the van so some dremell work is most definitely needed , there plenty of room still length wise though [emoji106]
And man that thing is definitely fast hopefully plenty of torque to boot !! Should be perfect for my needs
Had a very positive response from castle so hopefully they'll be able to sort something out for me
[emoji106]
Your right it would be too tight I'm getting mixed up thought the 1515 was the same size can as the 1512 or very close and just checked the specs and the 1512 fits and the 1515 is too big thanks for pointing that out man could of been another disaster [emoji15]
Ps I can't see the pic just a photo bucket banner telling me I need to update my account ! [emoji106]thanks again man
