Sr.Irie
IRIE Products Twin Hammer Steering & Axles
Irie's Twin hammer ball bearing bell crank steering & upright shock tower. I2
All parts 6061 T6 aluminum
Each bellcrank rides on two precision ball bearings for a no slop no maintenance steering
Shock tower is designed for G-made 85mm XD Piggyback shocks with no internal limiter or external bump stop to take advantage of the full travel of the shock
Geometry of linkage has been 3D modeled to have as little bumpsteer as possible, almost not measurable
What is included?
6061 Top Plate and steering arms riding on ball bearings, assembled
Composite Shock tower,
Center link consisting of two ball ends and a turnbuckle
2-M3x25mm screws, for the tie rods to bellcrank
2-M3x20mm screws, for the bellcrank arms
2-M3x14mm screws, for mounting F of top plate / F of shock tower
2-M3x12mm screws, for mounting R of top plate
2-M3x6mm screws, for mounting R of shock tower to top plate
4-M3 nylon lock nuts
For the upper shock mount reuse the factory cantilever posts
Recommended servo horn part numbers:
TLR1555 for 23T
TLR1556 for 24T
TLR1557 for 25T
GCM Tower Steering kit
Included in kit
Steering arms made from 6061 riding on ball bearing two per arm
2-6061 stand offs
2-M3x22mm screws
2-M3x25mm screws
4-M3 Nylock nuts
2-M3 Large washers
2-Offset ball ends
1-Center link
Here is an install video that GCM was nice enough to do. THANK YOU
<iframe width="640" height="360" src="//www.youtube.com/embed/TYAUWT6tgA4?rel=0" frameborder="0" allowfullscreen></iframe>
Irie's Race Prepped Twin Hammers CVD Axles
Axles are cryoed for strength
then reassembled with 4037 chromoly cross pin
and lubed with molybdenum disulfide.
All together it makes a smooth running and pretty bomb proof axle.
Recommend Vaterra HD outdrives to go with the axle's part #VTR232062
Irie open rear diff axles.
Also can do complete setup rear differentials. PM if interested
Irie Products Wheel Bearing Kit
This kit covers al wheel bearings needed for the Twin Hammers wheel bearings front and rear.
These bearings are precision quality rubber sealed bearings made in the U.S.A. not overseas.
Includes
2: 6mm x 12mm
6: 5mm x 10mm
For Prices Click Here IRIE PRODUCTS
What is included?
TLR1555 for 23T
TLR1556 for 24T
TLR1557 for 25T
Included in kit
2-6061 stand offs
2-M3x22mm screws
2-M3x25mm screws
4-M3 Nylock nuts
2-M3 Large washers
2-Offset ball ends
1-Center link
Includes
2: 6mm x 12mm
6: 5mm x 10mm
