Interest in Rally?
Rodney burned his up last weekend. Juan had to stop and let his cool several times. Mine gave me no problems but I don't expect it to last forever.
The idea on motors is to keep the speed of the truck close to stock. Everything else I run uses 3S so I don't want to buy 2S batteries.
If the stock motor is 4375 KV then the motor rpm on 2S is 31,500 rpm.
If I buy a Holmes 23T Handwound Torquemaster (2790 KV) and run it on 3S the motor rpm will be about the same: 30,969 rpm.
Also, using higher voltage for the same power output means less amps, which means less heat and a more reliable setup. I learned that from boats.
Totally makes sense to me.
I thought 2s was the rule, but I guess nothing is official. I think this must be where I got that in my head.
Also this is the class that most want to keep as a "stock" class and only real upgrades the steering servo and ESC so you can 2 cell lipo.
Yeah, I talked to Turtle and Rodney about my 3S idea last Saturday and they felt it would be ok.
Everybody immediately thinks I'm trying to go faster by running 3S, but I'm really not.
I have this 16x2 Speed Gems motor here so whether I run it or the stocker I'll have a spare motor for Saturday. What plugs do you need on the motor wires? I can set it up to do a quick swap. I'm off all day Friday.
I soldered it direct to the esc.
I'd really like to just do it right and not screw around with brushed motors.
The brushless motor in my Blitz is no faster than my trophy truck and will run all day on 2s without getting hot at all.
Instead I'll just keep burning up brushed motors, "to keep this cheap"
On alot of tracks all out speed doesn't matter, it just means you are going to crash harder.
Bad thing with trying to keep things spec is you are always gonna piss someone off. You and Juan just bought the brushed versions to fit in the class, but I am sure you both would have rather bought the brushless ones. I just spent $120 on 2s batteries to fit in the class.
It'd be cool to have a way to just do a speed check on all the rigs and just say, no rig can go faster than XXmph. Run 1s, 2s, 3s, 4s, brushed, brushless, whatever as long at your top speed wasn't over X. If you went a little fast just bring it in and gear it down.
I think everyone would agree that we'd rather see you there with something that runs than something that is going to die in 10 minutes. I say throw the brushless in there and come play.
Yea I feel ripped off by this motor. I never take anything back, but this might be going back to hobbytown.
I'll figure something out it looks like too much fun to miss out on.
off to bed...
At the rally track too much speed will hurt more than help. I can take the VXL combo out of my Slash if you want to borrow it.
off to bed...
Had the same problem with one of those motors. I have a 27t p2k you can have if you want for saturday. Or a 14x3 orbital 2r pro BB not sure if that would be over the limit though. The p2k has 0 runs on it soldered connections up and changed my mind and the bb needs the diodes re-soldered but only has a run or two on it. Could meet ya at the 7-11 on 112th there between us sometime this week if ya want. Shoot me a pm if you want em, they are just sitting here.
I agree 100% with your logic.
I was talking to Chris about this yesterday, and I don't want to go any faster, I just want the reliability of a good setup. Once my stocker smokes, I want to replace it once, not 5 times.
Ty, if we keep the motor RPM all the same (or close) can we go the inexpensive route and buy a good motor setup the 1st time?
Are you guys running any sort of heat sink to help keep temps lower?
My set-up is totally different, but I am having heat issues too (even with a heat sink, though it helped a lot) and I was looking at low-kv brushless motors as well, with the same mindset as grizz - keep the same KV as stock, and it will be just as competitive. I don't think you guys have to worry too much about my rally truck, the driver is the handicap. Also, my set-up fits my 3s batteries much easier, where as with the 2s I need to make a spacer to get it to stay in place.
I was looking at 2600KV motors, with 3S lipo (on a full charge - 12.6V) it's only 32,760 RPM, If grizz's calculation is right, the stocker on 2S is 36,750 RPM. So, really up to a 2900KV motor would be equivalent on 3S (36,450 RPM)
I think if the group agrees, this would be the new rule? It stays competitive, but for some people this is less expensive than burning up 2S batteries and brushed motors every run.
jason said:
All I said guys is keep the speed around stock, I don't care how it is done, never did. Never said you have to run 2 cell or brushed motors. That is just what I run.
The class rules are not so much rules as they are guidelines at this point.
Some people want to keep this strictly fun and run one fun event at a time. While I have heard others want to have a series with tracked points.
Its your guys' call what you would like to do. I don't think it will change anything all that much besides more then first place having bragging rights.
I will say that the class rules that are in place are not my creation. They have been in place by another group that comes to rally from time to time. And they do work.
So what do you guys want to do?
I think you and Rodney run a great event, so I trust your judgement on this as well.
I just want a truck that I don't have to work on every time it runs...I have enough of a work load with all my other trucks :ror:
I'm going to talk to Chris again about my motor size/RPM choices on 2S (since I also have 4 of them), and get a motor ready for when my stocker blows.
I have a couple vxl's here if they are allowed I will put one in and gear it appropriately.
Thanks I'll let you know if I decide to go that route.
I'll go with whatever everyone else wants, I just think it'd be a lot more fun for everyone if brushless motors were allowed. They are 100 times more reliable, so we could spend more time racing and less time cussing burnt up motors.
I won't argue with you there. The guys that put the rules in place made it a stock class so it was easy and inexpensive for everyone to get into.
Though...When one guy starts running brushless everyone thinks they have to and it becomes something of a deterrent to get new drivers and keep it affordable.
