Snowmaninhell
NOTE: I am just a scale enthusiast offering up my personal opinions. I do not receive any kickbacks for this review.
EDIT: February 7, 2013 - Thanks to BADASSPONY I went to asiatees site to do a little more research. It appears this is a TopCAD product and not Integy. I am also still unable to find any specs for this unit.
Review Date: February 6, 2013
ITEM
Integy Billet Machined Realistic Power Winch Scale Rock Crawler 1/10 Red
RATING
Four out of five Thumbs Ups "thumbsup""thumbsup""thumbsup""thumbsup"
FIRST IMPRESSIONS
I love the look of this winch. The first instant I saw it I knew I wanted it for my current build. I have personally never used Integy products, but have heard many others don’t think much of them. Setting those opinions aside I bit the bullet and bought one. Now I thought it would be nice to write a review for the new kid on the winch block. Additionally, I replaced the stock 2mm socket head cap screws with RC4WD Scale Hex Bolts and the stock cable with RC4WD Synthetic Winch Rope from my own inventory. Personally I find the Scale Hex Bolts and synthetic rope make the already great looking winch look even better. The modifications I made are not necessary and do not improve the performance of the stock winch.
SPECIFICATIONS
I have not found any specs for this winch online.
PROS
1. Solidly built from CNC’d billet aluminum.
2. Great looking design.
3. Stout 1/16 steel base plate.
4. CNC billet aluminum hook that easily fits RC4WD Mini Tow Shackles
5. Easily replacement of motor and gear reduction unit. It appears to be the same as RC4WD and 3Racing units.
6. Comes with a pig tail that plugs into a receiver and is controlled by a mountable three way switch.
7. Comparably priced to the competition at $35.
8. Several color options are available to best fit your build: polished aluminum or anodized red, black, green, and gun metal.
CONS
1. Motor and gear reduction unit is week. Spooling can easily be stopped by simply applying pressure to the line by hand while in use. Comparable to the competitor winches.
2. Stock cable is only 42” long and is Nylon coated. I have found Nylon coating tears easily. This can make a neat and tidy re-spool a challenge.
3. Heat sync looks out of place, as if it was an afterthought and quickly machined to cover up the motor.
4. Mounting holes under the motor are a bit tricky to access even after sliding the heat sync off the motor.
SUMMARY
I would definitely recommend this winch to those who want an awesome looking winch to show off on the front/rear of their rig. It looks very tough. However, don’t rely on it to get you out a bind while on the trails. It could be used a dummy in front of a servo winch to get the best of both worlds.
SOURCES
Stock Integy Winch – Integy or RPP Hobby
RC4WD Scale Hex Bolts – RPP Hobby or RC4WD
RC4WD Synthetic Winch Rope – RPP Hobby or RC4WD
PICTURES
Integy’s Stock Photo
My Photos Showing RC4WD Parts Installed
ITEM
RATING
FIRST IMPRESSIONS
SPECIFICATIONS
PROS
CONS
SUMMARY
SOURCES
PICTURES
