Infectious rc
Presents:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Aluminum Losi Mini Rock Crawler Servo Mount
(Allows you to run a full size servo (center mounted), includes link mounts and an electronics/battery tray)
This is a direct replacement for the Losi MRC Pro mini servo mount plate.
If you want to use a full size servo, would like to keep your factory upper link geometry, and could use a place for your electronics or battery between your upper links, you will love our new MRC Servo Mount!<o></o>
Installation is a breeze; this is truly a bolt-on upgrade!
You simply unbolt your factory servo plate and front upper links from the front axle and bolt on this plate in its place.
Quantities are limited to stock in hand.
These servo mounts are $28 each shipped.<o></o>
Please PM us with your request and we will send you our PayPal address for payment.
Orders will be based on a first come, first served basis, so don’t wait!<o></o>
You have the option to run the mount straight as it is delivered to you, you could put a single bend to lower the plate, or even put two bends in it to drop it right above your driveshaft.
Or, If you don’t want or need the tray, you could also remove it all together.
Customer applied single bend -------------------- Customer applied double bend
