StomperCrawler
Crawling n00bz need tutz on how to crawl. Any experienced-types willing to help train us up? Some of what I've learned so far from y'all + limited experience:
- Not all crawlers are created equal:A) Rock Racers (EXO Terra, Wraith, Twin Hammers) are made for speed and not crawling
B) Scalers (RC4WD, SCX10) are not Comp Crawlers but can crawl OK
C) Less-expensive Crawlers (RedCat, Exceed) are fun for trails and can crawl OK if modded slightly (upgrade servos to MG high-torque for $12, tires, etc)
D) Comp Crawlers (AX10, XR10) are slow and precise - Setup matters:A) Sticky & soft tires are a necessity for crawling
B) BEC is required for upgraded servos unless you want to fry your ESC - Managing weight matters:A) Keep COG (Center Of Gravity) low
B) More weight should be on the front axle - Crawling is more than just pulling the trigger and steering:A) Pulling the trigger when stuck breaks things
B) Turning (with a high-torque metal-gear servo) can un-stick you
C) There are invisible lines/routes that are better than others (but how to find them?!? :???: ) - Comp Crawling has rules like:A) Rear-steer = prohibited
B) Front/Rear DIG = encouraged
