Crawler Cads
Just wondering what foams youve tried as a comparison to your current method on your crawlers of over stuffing with open foam?Good idea covering the foam inserts with grease. Depending on the rubber compound though, silicone grease might not be a good choice. A lot of closed-cell foams nowadays are also silicone, and nothing destroys silicone rubber faster than silicone oil or grease.
I have tried high-end foams. (EDIT: except for those awful memory-foams that Pro-Line includes with some of their tires.) That's how I know I prefer the stock foams. Yes, I know, I'm a very strange man. I run closed-cell foams in my buggies and SCTs, and I have a stash of discontinued HPI 1.9" x 26mm closed-cell foams for touring car tires that I use on one of my touring cars, but I run open-cell foams in everything else. Closed-cell has too much impact rebound for off-road driving, in my opinion; the air trapped in the closed-cell foam increases in pressure very rapidly as the tire squishes on impact, so it bounces back much harder as well. Whereas with open-cell foam, the air isn't trapped inside the foam, so the impact is absorbed by compressing the foam itself, and the foam doesn't rebound nearly as vigorously as the air trapped inside closed-cell foam. It matters even more for solid-axle trucks like rock crawlers, where the suspension doesn't do much to absorb impacts because most of the truck's weight unsprung weight. That's the best explanation I can give as to why I prefer open-cell foams in my crawler tires. If it's any consolation, all of my crawler tires are overstuffed to give the foams some "preload".
Sent from my Pixel 3 using Tapatalk
