MiniMorris
This is a snowblower I made for the winter season. Only spent about $20 in materials. Took a lot of hours though. If a 16 year old can build it, you can too.
In Action:
https://www.youtube.com/watch?v=w6sMqdzFio4
https://www.youtube.com/watch?v=rbBGx0MF8SE
https://www.youtube.com/watch?v=BoVO7Lw0enU
http://www.youtube.com/watch?v=2-Ptu5IT7nI&feature=youtu.be
How it's made:
Started with a 260 sized motor and soldered a square (25x25mm) 1/16" thick brass sheet to the brass pinion.
Cut and bent.
Bent up corners for support and soldered.
Auger started as 1/16'' brass sheet.
After many hours on the dremel. Main housing is 22ga steel. Main brass shaft is 3/16" and used one size up for the bearing bushing (far right).
JB Welded to motor to a PVC piece I found at Lowes
Coupler is from a boat, drilled it to proper size.
Chute made from brass sheet.
JB Welded to Blower
More JB Weld...
Mounted
Paint and polish goes a long way. Clear coat went on after Decals.
Hinged mount for the project Jeep. Will be winched raise/lower.
Adjustable plexiglass feet.
Styrene, 6amp switch, and 18ga solid to imitate hydraulic lines or electrical.
Id say looks pretty good!
Thanks for looking! "thumbsup"
In Action:
How it's made:
Cut and bent.
JB Welded to Blower
More JB Weld...
Mounted
