hillbillyrc
BIG UPDATE!
I might be wrong but this could be the first forward mounted motor in a barrage platform!
First I flipped the front scx10 shock hoops to sit on the outside of the chassis.
Now my R2 trans will fit between the hoops.
This is probably the main reason it has taken so long to get here. CUTTING THE CHASSIS. The trans is 70 mm wide. So is the inside of the chassis but it being a C- channel chassis some parts need to be removed. No turning back now.
I had to test fit a couple times to make sure I didn't cut to much away. Right now its has one bolt on each side the also mounts the back side of the shock hoops. I still need to drill one more hole of each side.
Mocking up my t-case and checking my driveline angle.
